Revit’s [TessellatedShapeBuilder] function
1146279845
1146279845
Hello, why does it fail to call Revit’s [TessellatedShapeBuilder] function when the number of triangles is more than 45000? Is there any way to solve this problem?
jeremytammik
Please provide a minimal reproducible case and I can ask the development team whether it is intentional for you.
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
When " TessellatedShapeBuilder.Target= TessellatedShapeBuilderTarget.Mesh,
TessellatedShapeBuilder.Fallback=TessellatedShapeBuilderFallback.Salvage" and the number of triangles is greater than 675675, tessellatedshapebuilder. Build() failed
When " TessellatedShapeBuilder.Target=TessellatedShapeBuilderTarget.Solid,
TessellatedShapeBuilder.Fallback=TessellatedShapeBuilderFallback.Abort" and the number of triangles is greater than 45000, tessellatedshapebuilder. Build() failed
Why is there so much difference between solid and mesh?
Thank you very much
jeremytammik
I cannot say why there is a difference between the two, but one thing is clear:
Remember that Revit is a BIM tool.
Are you really using it for a BIM, or some inappropriate use case?
What do the shapes represent that you are creating?
Are they building elements?
If so, that will end up being a pretty complicated building.
Jeremy Tammik
The Building Coder
