Revit Run in Automation Mode
manuel_f_perezii
manuel_f_perezii
Hello Everyone and thank you.
I have a powershell script that will load a revit application and most likely will call a revit plugin. Below is my powershell script, addin and the class of my plugin.
# Path to Revit EXE
$revitExe = "C:\Program Files\Autodesk\Revit 2024\Revit.exe"
# Path to your generated journal
$journalPath = "C:\Users\xxxx\AppData\Local\Temp\revit_auto_6e7001a415554ea7af4fb16612599dd9\auto_journal.txt"
# Start Revit with /automation
$tempDir = "C:\Users\xxxx\AppData\Local\Temp\revit_auto_6e7001a415554ea7af4fb16612599dd9"
Start-Process -FilePath $revitExe -ArgumentList "/automation `"$journalPath`"" -WorkingDirectory $tempDir -Wait
addin file
<?xml version="1.0" encoding="utf-8"?>
<RevitAddIns>
  <AddIn Type="Command">
    <Name>BatchKeynoteUpdater</Name>
    <Assembly>C:\Users\xxxx\source\repos\version app.dll</Assembly>
     <AddInId>xxxx</AddInId>  <FullClassName>app.UpdaterCommand</FullClassName>
    <VendorId>x</VendorId>
    <Publisher>x</Publisher>
    <VendorDescription>x</VendorDescription>
    <CommandType>Automation</CommandType>
  </AddIn>
</RevitAddIns>
namespace app
    [Transaction(TransactionMode.Manual)]
    public class UpdaterCommand : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
          log("this is called");
My problem here is that the updatercommand execute was never called at all by using the powershell script.  Doing this manually or clicking the revit plugin works.
I am kinda stuck on this scenario. Before I posted here I tried to look for answers via AI and I exhausted all the recommendation.
If anyone has idea feel free to commend and thank you in advance.
charlesyip913
Observer
Observer
Hi, can you share what’s in your journal file? Did you include a Jrn.RibbonEvent call to trigger the command? Also, I’m not sure if your snippet was trimmed, but it looks like you’re missing the return Result.Succeeded; statement. If the code doesn’t compile cleanly due to syntax errors, Revit won’t run the command.
manuel_f_perezii
Yes I have trimmed some code, and yes it returns Result.Succeeded; I just forgot to paste it on the code.
This is the autojournal text
Dim Jrn
Set Jrn = CrsJournalScript
' open RVT file
Jrn.Command "Ribbon", "Open an existing project , ID_FILE_OPEN"
Jrn.Data "File Name" , "ModelPath" , "C:\Users\xxx\Desktop\revit docs\Link Testing\Link Testing2\MainModel.0011.rvt"
Jrn.Wait "20"
' run your external command
Jrn.RibbonEvent "Execute external command:xxx:app.UpdaterCommand"
' exit Revit
Jrn.Command "Ribbon", "Exit Revit , ID_APP_EXIT"
jsantana49YZQ
Observer
Observer
Hello @manuel_f_perezii, I try also to test execution of a command with automation mode but it doesn't work for me either.
So I have a question, where did you find documentation on this?
Thanks in advance
