Delete Schedules and views placed on sheets from project then delete sheet
mike_frelich2
mike_frelich2
I am trying to write a script that will delete all schedules and views placed on the sheet from the project then delete the sheets, I have been able to get the views and sheets to delete but i can get the schedules to. Can anyone tell me where im going wrong with the schedule delete code?
sensiblehira
use
ScheduleId
property instead of ViewId for ScheduleSheetInstances to get the schedule's Element Id and directly use it to delete the schedule.
sensiblehira
and the output for both ViewId and ScheduleId is ElementId, so you do not need to get the element again to delete it. Directly use the ElementIds to delete elements
ctm_mka
curious, why not delete just the sheet? technically no need to delete view and schedules first.
mike_frelich2
I wasn't able to get that to work, I'm assuming i didn't swap out the correct callouts to ScheduleId
mike_frelich2
We create fabrication drawings so each sheet has a unique schedule and detail views created for that sheet alone so if we need to update the sheet we essentially need to delete all of them before re-running the sheet creation script. Part of trying to get this script working properly is to add it to the sheet creation script so it will auto do it if a sheet with the name its trying create so it makes two steps into one.
mike_frelich2
This script works without issue (for as much as i tested it in R21 thru R24)
