.Revit.Proxy.Exceptions
aclarke
Message 1 of 12
aclarke
Hi all,
I am wanting to delete all the Elevation Views from a model.  I am running into this exception:
Autodesk.Revit.Proxy.Exception.InvalidObjectExceptionProxy
I assume I need to load a Reference for 'Proxy' but I am not sure, nor can I find where to load from, it i not with the other .dll files.
I am trying to figure out which view or what is throw the exception or why it is happening
Thanks for any assistance...  🙂
t.Start();
List<View> views = myFunctions.CollectedViews(doc);
List<ViewType> viewTypes = myFunctions.ReturnListOfViewTypes(doc);
foreach (View v in views.Distinct())
    if (!v.IsTemplate)
        foreach (ViewType vt in viewTypes)
            if(vt == v.ViewType)
                try
                    doc.Delete(v.Id);
                catch (Autodesk.Revit.Proxy.Exceptions.InvalidObjectExceptionProxy)//<-- No Good
                    TD(v.Name);// TaskDialog.Show shortcut
t.Commit();
Replies (11)
Message 2 of 12
TripleM-Dev.net
Not sure about the Proxy message (strange), but a couple of things:
- Views.Distinct not needed if you want to delete all elevation views (would always be unique)
- Make sure one of the open views isn't a Elevation! This gives a error message in the Revit UI
- Is the error raised at the first deletion ?
- in place of doc.delete(v.id), collect the id's in a collection and delete them together AFTER the loop.
- What is the viewTypes collection contain?
- Make sure not to try and delete a dependent view if parent view is already deleted.
See code below, do check if a non-elevation view is open first!
    FilteredElementCollector ViewCollector = new FilteredElementCollector(doc).OfClass(typeof(View));
    List<ElementId> DeleteViewIds = ViewCollector.Cast<View>.Where(v => (!v.IsTemplate) && v.ViewType == ViewType.Elevation && (v.GetPrimaryViewId != ElementId.InvalidElementId)).Select(e => e.Id).ToList;
    using (var t = new Transaction(doc, "Delete Elevations"))
        t.Start();
        doc.Delete(DeleteViewIds);
        t.Commit();
- Michel
Message 3 of 12
aclarke
I figured out why I was getting this error...
The collection grabs all the views, and I failed to filter for Primary from the Dependent views, so as the deletion iterates thru the list of ID's, once the primary is deleted and then it gets to the dependent Id, the element is no longer there because it was deleted with the primary.
Filtering into two lists, a primary and dependent, then delete all the dependent views first then the primaries views fixed my issue.
I am still curious for the Revit.Proxy Exception
Message 4 of 12
aclarke
Thanks for the example code.  I like seeing examples of LINQ.  I am trying to do more with LINQ but I still struggle with it.
the Distinct() was me trying to understand how an ID was being deleted then trying to delete again, so I thought the ID was being captured twice...  I was throwing rocks at the problem trying to figure it out.
viewType collection:
It was going to contain a list of all the view types I wanted to delete, but this doesn't seem feasible now, seems better to tackle each view type independently.
Thanks for your reply
public static List<ViewType> ReturnListOfViewTypes(Document doc)
    return new List<ViewType>()
        ViewType.Elevation
Message 5 of 12
TripleM-Dev.net
I didn't test the code, below a correction for functional code:
            List<ElementId> DeleteViewIds = ViewCollector.Cast<View>().Where(v => !v.IsTemplate &&
                        v.GetPrimaryViewId() == ElementId.InvalidElementId).Select(e => e.Id).ToList();
                t.Start();
                t.Commit();
Below a sample for using grouping on a property, ViewType in this case.
            var groupedData = ViewCollector.Cast<View>().Where(v => !v.IsTemplate && v.GetPrimaryViewId() == ElementId.InvalidElementId).GroupBy(v => v.ViewType);
            foreach (var group in groupedData)
                var groupkey = group.Key;
               //if(groupkey == ViewType.Elevation)
               //     // only do something now
                foreach (var groupeditem in group)
                    // the Views = groupeditem for the Viewtype = groupkey
- Michel
Message 6 of 12
aclarke
Another great LINQ example...   I will use this...
Thank you for sharing with me..  🙂
Message 7 of 12
aclarke
Why the use of 'var' because I wouldn't know to use it for this case?
Message 8 of 12
TripleM-Dev.net
It's just easier:
is identical to, both can be used.
IEnumerable<IGrouping<ViewType, View>> groupedData = ViewCollector.Cast<View>().Where(v => !v.IsTemplate && v.GetPrimaryViewId() == ElementId.InvalidElementId).GroupBy(v => v.ViewType);
The type of groupedData is already inferred because of the GroupBy.
If that's what you mean?
- Michel
Message 9 of 12
aclarke
you have answered my question,
Message 10 of 12
TripleM-Dev.net
No thanks.
Please mark thread then as solved, for other users.
- Michel
Message 11 of 12
aclarke
I am confused by your 'no thanks'
Message 12 of 12
TripleM-Dev.net
Sorry, poor choice of words on my side.
No thanks needed. 😂
