Nodes
Nodes
deoca.revit
Nodes
deoca.revit
Hi
How do i create nodes in revit to use then in Lumion for object replacement?
jeremytammik
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to any question relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
deoca.revit
Sorry and thanks for the clarification, realized this was not the correct forum to submit my question after the same was submitted.
