REVIT PROBLEMS
REVIT PROBLEMS
REVIT PROBLEMS
I USE BOTH REVIT 2016 AND 2017 ON MY COMPUTER, AND NOW NEITHER VERSION WILL OPEN, I RECEIVED A PATCH FROM AUTODESK WHICH I HAD INSTALLED & IT DID NOT WORKED I EVEN TRIED UNINSTALLING AND INSTALLING THE PRODUCTS AGAIN AND I AM STILL GETTING THE SAME ERROR, I HAVE TRIED EVERY POSSIBLE THING I CANT THINK OFF BUT MY PROGRAM WONT OPEN.
THE ERROR MESSAGE SAY:-
[ AN UNRECOVERABLE ERROR HAS OCCURRED. THE PROGRAM WILL NOW BE TERMINATED. ALL OF YOUR DATA HAS BEEN RECENTLY SAVED, SO THERE IS NO NEED TO CREATE A RECOVERY FILE.]
I HAVE ATTACHED A COPY OF THE ERROR BELOW
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
By the way, good Internet netiquette advises against all caps:
https://newrepublic.com/article/117390/netiquette-capitalization-how-caps-became-code-yelling
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
