Message 1 of 1
Change data in Key schedule
I'm trying to bring in some text from an Excel file and use it to populate a key schedule I already have created in Revit. The key schedule that I want to modify will be the active view when I use this command. I've figured out how to access and store the Excel data but I can't figure out how to push it into the schedule.
This is what I have so far:
//List to store each class object associated with the RowData class
//which in turn holds the data from each row in the Excel file.
List<RowData> rowList = new List<RowData>();
for (int r = 1; r <= rowCount; r++)
//This addds the new instance of the class RowData to the list rowList.
rowList.Add(new RowData());
rowList[r - 1].NoteNumber = xlRange.Cells[r, 1].Value2;
rowList[r - 1].NoteText = xlRange.Cells[r, 2].Value2;
UIDocument uiDocument = commandData.Application.ActiveUIDocument;
Document document = uiDocument.Document;
View activeView = uiDocument.ActiveView;
Transaction t = new Transaction(document, "Import Schedule Footer Notes");
t.Start();
//I want to go through the key schedule row by row and update the first 2 cells in that row.
foreach (RowData n in rowList)
//I'm not sure what to put here to change the text in the cell.
//current row first cell = n.NoteNumber;
//current row second cell = n.NoteText;
t.Commit();I am new to the api and relatively new to programming so an example would help but an explanation of the example would be even better. I'm trying to learn.
