Revit Lookup problem with CategoryId
Shai.Nguyen
Shai.Nguyen
Hi Jeremy and everyone,
First of all, I would like to thanks Jeremy Tammik, who create Revit Lookup so I can easily find all information of an element.
When I debug a view schedule, its DefinitionId.CategoryId has a value (-2008044), but when I lookup in revit, DefinitionId.CategoryId is null.
Why in this case it's null? Because I want to lookup which category this view schedule belong to.
cat2.PNGThank you,
Shai.
jeremytammik
Thank you for your appreciation. Glad you like it.
A negative category id refers to a built-in category.
Look at the BuiltInCategory enumeration values in the debugger and you will see:
I cannot comment on why you see different values in the two places.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jlpgy
Hi:
I looked up the API help document.
Enum integer value -2008044 is 'OST_PipeCurves'.
This element should be a Pipe or FlexPipe.
        public static BuiltInCategory GetBuiltInCategory(this Element elem)
            Category category = elem.Category;
            if (category == null) return BuiltInCategory.INVALID;
            return (BuiltInCategory)category.Id.IntegerValue;
Very wierd, I'm not familiar with ViewSchedule.Robot Sad
单身狗;代码狗;健身狗;[email protected]
Shai.Nguyen
I'm not quite sure but I expect its value like this instead of null
Otherwise is there any other way to find category which view schedule is belong to by Revit Lookup?
