Revit links graphic overrides
Message 1 of 25
Is there a way to access the "Revit links graphic overrides" (cf : picture) from the API. I can't find any properties/methods to manipulate them, and if I use the builtin parameter associated to it (BuiltInParameter.VIS_GRAPHICS_RVT_LINKS) it always returns null. Any idea?
Replies (24)
Message 21 of 25
Luffy11
@naveen.kumar.t ,
Yeah I followed that sample, but it always returns None and I don't know why.
Message 22 of 25
Luffy11
Hi @naveen.kumar.t ,
When I try to provide a RevitLinkType, it works. Thanks for your suggestion. Then I still need to set the Halftone and Underlay, but they're not available for now, is that right?
Message 23 of 25
steven.williams.as
I think you need to use RevitLinkType, not RevitLinkInstance. Also don't pass in a view filter, because types do not have a host view. You can filter that out later if you need. 2025 introduces support for more options. RevitLinkGraphicsSettings Class
link_types = FilteredElementCollector(doc).OfClass(RevitLinkType)
# note that you need to be in a view that supports overrides
# (not a schedule, title sheet, etc.)
for link_type in link_types:
	if uidoc.ActiveView.ViewTemplateId == ElementId.InvalidElementId:
		target_view = uidoc.ActiveView
	else: # view has template, so use the template overrides
		target_view = doc.GetElement(uidoc.ActiveView.ViewTemplateId)
	overrides = target_view.GetLinkOverrides(link_type.Id)
	print('{}: {}'.format(link_type.Name, overrides.LinkVisibilityType))
# prints something like
# File 1 Base.rvt: Custom
# File 2.rvt: Custom
Message 24 of 25
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Luffy11 ,
As far as I searched, The Halftone and Underlay API for Visibility/Graphics settings overrides does not appear to be exposed.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 25 of 25
Luffy11
I got it, thanks a lot for your help @naveen.kumar.t  @steven.williams.as
