Revit is unresponsive when trying to change a file location under Options
bart_osburn
bart_osburn
hello,
i am setting up a new computer with Revit 2018. this involves changing the file locations under options. i browse to the new file location and hit open and the dialog box just blinks. i can not cancel out of it or X out, i have to use task manager to kill it. any ideas? i have uninstalled , reinstalled, and updated to 2018.1
i have also changed default system printer to Adobe PDF and unplugged 1 monitor (because that is what google told me to try)
this is a part of design suite premium 2018, all other programs run fine
thank you for your help
bart
bart_osburn
my apologize i have put this in the wrong forum. how to i move it to Revit Architecture?
eason.kangEDLV4
Autodesk Support
Autodesk Support
Dear Bart Osburn,
Apologizing for the late response. We had a backlog in the queue.
Because the issue you addressed is not related to the Revit API, I've escalated this case to the product support team for your convenience this time.
You should log product related issues on the Revit Architecture Forum, Revit MEP Forum or Revit Structure Forum next time.
Cheers,
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
