Revit DWG export setups?
SmaakJeda
Observer Observer
SmaakJeda
Observer
Observer
How can you export these settings or set them as the default for the program and where are my previously created export setups if it even saves the information? I spent hours setting it up. I saved the file after I was done but when I needed to revise an item I wanted to export the same file but my export setup was gone....
Even the help button in the Modify DWG/DXF Export Setups doesn't work. Any help would be appreciated!
SmaakJeda
Observer
Observer
Update:
I did find a file that has saved the export setup. The settings can be shared between projects by using the "Transfer Projects Standards" functions.
