Revit DWG export setups?
- Mute
- Permalink
- Report
How can you export these settings or set them as the default for the program and where are my previously created export setups if it even saves the information? I spent hours setting it up. I saved the file after I was done but when I needed to revise an item I wanted to export the same file but my export setup was gone....
Even the help button in the Modify DWG/DXF Export Setups doesn't work. Any help would be appreciated!
