Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit crashes (wpf)
3 REPLIES 3
vano96711
2072 Views, 3 Replies
Revit crashes (wpf)
vano96711
Hello everyone. I have a problem when using WPF in revit api.
I use MVVM pattern. Revit crashes, when an unexpected exception occurs in ICommand. Try/catch in IExternalCommand doesn't help. Tried use AppDomain.CurrentDomain.UnhandledException and AppDomain.CurrentDomain.FirstChanceException.
I also tried using WPF template without MVVM (https://thebuildingcoder.typepad.com/blog/2020/01/revit-wpf-add-ins-and-template.html). I put a "throw new Exception()" in the button click handler. Revit also shuts down.
How can I avoid this problem?
The user can work with large projects. I would hate to lose progress because of an unexpected error.
Revit crashes (wpf)
Tags (3)
3 REPLIES 3
Sean_Page
in reply to: vano96711
Sean_Page
Can you provide any portion of the code related to the error, the error message details, and a little more description of when / how the error occurs? I don't believe your current description "it isn't working" is really enough for anyone to be able to help you very well.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
3dimdev
3dimdev
Do you have instances of Revit elements in your ViewModels which have properties bound to your UI?  Revit can (will always?) CTD when a binding attempts to access a Revit element that is no longer valid.
3rd Dimension Developer
YouTube.com/@3DimDev
Moustafa_K
Moustafa_K
I recall I have given an example of how these works see this post.
let us know what was the error you experienced so we can be able to assist
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Moustafa Khalil
