Revit Could not load c:\...revit2021\intflFC.dll problem
guilhdec
guilhdec
Community Visitor
Community Visitor
I've tried several times to install the program, however I aways enconter this problem. I've tried to uninstall, delete every trace of autodesk related documents, downloaded in every possible way and I aways see the same thing when I try to open Revit "Revit could not load..." I can't find any solution to this. Please someone help me, I'm losing my mind on this, and I really need this thing to work.
Ps.: I have the student licence
jeremytammik
Sorry to hear about your struggles.
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi there, I have the same problem. Did you find a solution?
jeremy_tammik
I repeat my answer above. This is not the appropriate place to discuss such a question.
So, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
The people there are much better equipped to address this topic than us programming nerds.
Best regards,
Jeremy
