Revit command - go to URL
Good afternoon
I would like to find a way to have a link to a website on the Revit ribbon.
Are there any recommendations on how to achieve this?
This video is exactly what I am looking to do, but there is no explanation:
https://www.youtube.com/watch?v=wfMzmuJ2xfA
Thank you!!
studio-a-int
you need to open a process using Process class from System.Diagnostics
just need to insert in your code something like this:
string url = "http://www.autode.sk";
System.Diagnostics.Process.Start(url);
and depends on how system is configured on machines where your addin will run, you need to catch specific exceptions.
@studio-a-int, thank you so much for your response! It is much appreciated!
I am very new to the concept of what I am assuming is coding.
I honestly am not too sure what your answer means.
Do I need to use a Revit API kit of some sort?
I found a few posts and blogs, but it looks so daunting and nothing appeared in my "for dummies" search string...
I have considered re-routing F1 from Revit help to my intranet knowledge base, or creating a keyboard shortcut.
But I know my team. They need something right there or they will find a workaround to get a result and never ask me to show them how to do it properly...
studio-a-int
you will need to create a ribbon, add a push button to it, and trigger the command in the button using a simple class in your namespace, something like this:
    public class yourCommand : IExternalCommand
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData ecd, ref string rs, ElementSet es)
            return Autodesk.Revit.UI.Result.Succeeded;
here is the API documentation for RibbonPanel Class w/ methods:
https://www.revitapidocs.com/2020/544c0af7-6124-4f64-a25d-46e81ac5300f.htm
marcusss_
Thanks for this, it helped me out.
Thought i would mention also just as an FYI to anyone else if it may help them as i had to figure this part out.
I had to add
[TransactionAttribute(TransactionMode.ReadOnly)]
before the class in the code, as a...
"TransactionMode must be applied to your implementation class of the IExternalCommand interface to control transaction behavior for the external command."
Cheers
https://help.autodesk.com/cloudhelp/2018/ENU/Revit-API/Revit_API_Developers_Guide/Introduction/Add_I...
ridaabderrahmane
You might consider to do it with on F1 click, it should be like this :
ContextualHelp contextHelp = new ContextualHelp(ContextualHelpType.ChmFile,"https://www.autode.sk");
yourButton.SetContextualHelp(contextHelp);
