Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit API
4 REPLIES 4
727 Views, 4 Replies
Revit API
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports Autodesk.Revit.ApplicationServices
Imports Autodesk.Revit.Attributes
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.DB.Events
Imports Autodesk.Revit.DB.Architecture
Imports Autodesk.Revit.DB.Structure
Imports Autodesk.Revit.DB.Mechanical
Imports Autodesk.Revit.DB.Electrical
Imports Autodesk.Revit.DB.Plumbing
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.UI.Selection
Imports Autodesk.Revit.UI.Events
Imports Autodesk.Revit.Exceptions
Imports Autodesk.Revit.Utility
Imports RvtApplication = Autodesk.Revit.ApplicationServices.Application
Imports RvtDocument = Autodesk.Revit.DB.Document
Public Function Execute(ByVal commandData As ExternalCommandData, ByVal message As ref, ByVal elements As ElementSet) As CmdResult
i have problem here , Please can you tell me what is the problem.
Statment is not valid in the Namespace.
Dim app As Application = commandData.Application
Dim doc As Document = app.ActiveDocument
Dim e As New Element()
Dim num As Integer = 1
Dim it As ElementIterator = doc.Elements
Do While it.MoveNext()
e = it.Current [as] Element
Try
' get the BuiltInParameter.ALL_MODEL_MARK paremeter.
' If the element does not have this paremeter,
' get_Parameter method returns null:
Dim p As Parameter = e.get_Parameter(BuiltInParameter.ALL_MODEL_MARK)
If p IsNot Nothing Then
' we found an element with the
' BuiltInParameter.ALL_MODEL_MARK
' parameter. Change the value and
' increment our value:
p.Set(num.ToString())
num += 1
Catch ex As Exception
Util.ErrorMsg("Exception: " & ex.Message)
End Try
Loop
doc.EndTransaction()
Return CmdResult.Succeeded
End Function
Revit API
Imports System
Imports System.Linq
Try
num += 1
End Try
Loop
End Function
4 REPLIES 4
mhillis
mhillis
The code you posted does not have a namespace.
Imports System
Imports System.Linq
Namespace YourProject
      'your code goes here.
   End Function
End Namespace
Imports System
Imports System.Linq
   End Function
End Namespace
in reply to: mhillis
i added the namespace even but than even it does not work.
Namespace Removal
Try
num += 1
End Try
Loop
En()
End Function
End Namespace
Namespace Removal
Try
num += 1
End Try
Loop
En()
End Function
End Namespace
jeremytammik
jeremytammik
Please work through the Revit API getting started material, especially the DevTV and My First Revit Plugin tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Then all will become clear.
Have fun!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Have fun!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
mehsan
in reply to: jeremytammik
mehsan
I am not so much experts in this still learning, but i need this API please can you correct and Send me, Thanks
