Revit API view current phase
I'm attempting to get access to my view's current phase via the API to compare the current phase to the phase created of the elements in that view. I.m having trouble accessing the phase of the view or floor plan. I've checked out and used several previous posts on this forum and have had no success.
Here's my code for trying to access the view's current phase.
View active = commandData.Application.ActiveUIDocument.ActiveGraphicalView;
string currentPhaseId = active.get_Parameter(BuiltInParameter.VIEW_PHASE).AsString();
Thanks in advance!
jeremytammik
Dear Hersh,
Thank you for your query.
I see you submitted two separate threads for this question, and Naveen already very kindly answered you in your other thread:
https://forums.autodesk.com/t5/revit-api-forum/revit-api-view-current-phase/m-p/8860806
So, we can ignore this one, then, I assume.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
