Missing Method
Missing Method
LightStanza
Missing Method
LightStanza
Hi all,
I am currently working to support Revit 2020 but a method I am using from the RevitAPI.dll says that it will be removed in 2020 so it won't be backwards compatible with Revit 2018 and Revit 2019. How can I get around this when submitting the app to the Autodesk app store?
Mitch
jeremytammik
Either submit separate versions of your add-in for separate versions of the Revit API, or, alternatively, implement multi-version support for your add-in using .NET Reflection.
That enables functionality to dynamically select the appropriate version of the method depending on what version or Revit your add-in is currently running in.
Here are some examples:
https://thebuildingcoder.typepad.com/blog/2012/07/multi-version-add-in.html
https://thebuildingcoder.typepad.com/blog/2015/05/compatibilizar-entre-vers%C3%B5es-api-compatibilit...
Jeremy Tammik
Developer Technical Services
The Building Coder
