revit api use c# draw a arrow connect to textnote in floor plan
m11105508
m11105508
hi,everyone
i want to draw a arrow with textnote in floor plan
now i can use line to draw it,but it is not good enough!
this is my result:
this is my code:
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Visual;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using static System.Windows.Forms.VisualStyles.VisualStyleElement;
using Autodesk.Revit.ApplicationServices;
namespace BIM_API_test1029
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
internal class TakeNote : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
MessageBox.Show("請選擇標示的點:");
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
if (uidoc == null)
MessageBox.Show("Error", "No document is currently open!");
return Result.Cancelled;
XYZ position1 = uidoc.Selection.PickPoint("pick the text origin");
XYZ position2 = uidoc.Selection.PickPoint("pick the 2nd point");
XYZ position3 = uidoc.Selection.PickPoint("pick the 3rd point ");
double width = 1.0; // <== 1.0 feet on paper
string text = "這裡有錯誤,請同學修正!";
ElementId textType = uidoc.Document.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType);
using (Transaction trans = new Transaction(uidoc.Document, "New Text Note"))
trans.Start();
Line line = Line.CreateBound(position1, position2);
Line line1 = Line.CreateBound(position2, position3);
DetailCurve detailCurve = doc.Create.NewDetailCurve(doc.ActiveView, line);
DetailCurve detailCurve1 = doc.Create.NewDetailCurve(doc.ActiveView, line1);
TextNote.Create(uidoc.Document, uidoc.ActiveView.Id, position3, width, text, textType);
trans.Commit();
return Result.Succeeded;
jeremy_tammik
Do it in the user interface to suit your needs.
Then, reproduce the same result using the API.
The API will not do anything more than the UI does.
m11105508
ok,thank you
ouob
