Revit API Selecting Linked Objects
Message 1 of 9
When using Revit with linked Revit files, I can select an indivitual element with Tab/Select and view some properties. However, if I run Snoop Current Selection, it comes up blank. Is there a way, through the API to Tab/Select such an entity?
Billy
Replies (8)
Message 2 of 9
Joe.Ye
Current Revit API cannot access the selected objects in linked model (Revit 2013).
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
I was wondering if this has been changed for Revit 2014?
I just did a quick test, and it appears that elements selected in a linked model are stil not part of ActiveUIDocument.Selection.Elements. Is there still no way for the API to return elements selected in a linked model?
Smiley Frustrated
Message 4 of 9
Joe.Ye
Revit 2014 exposed the API functionality to pick elements in linked model.
PickObject & PickObjects can pick elements in linked model.
Joe Ye
Contractor
Message 5 of 9
jeremytammik
Hi agimpert,
I just answered you related question on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2013/03/revit-2014-api-and-room-plan-view-boundary-polygon-...
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 9
Thank you both for the quick answers!
Adam
Message 7 of 9
jeremytammik
Hi Adam,
Thank you for the appreciation!
Here is another idea regarding the selection of elements in a linked file:
http://thebuildingcoder.typepad.com/blog/2012/05/selecting-a-face-in-a-linked-file.html
Cheers, Jeremy.
Jeremy Tammik
The Building Coder
Message 8 of 9
jeremytammik
Dear Adam,
Just for future reference, I submitted a wish list item SPR #237075 [PickObjects in linked document] for this.
Cheers, Jeremy.
Jeremy Tammik
The Building Coder
Message 9 of 9
hi all,
i understand that it's not possible to select elements in a linked file. Bevor i found this thread i tested it by myself. Actually we have the same issue. We want to identify and select elements (own generic models) by button to copy them in the current Revit file using clipboard.
The identification of these elements was easy. The filter returns 37 elements (view screenshot), but the elements are not selected in the active view and if i push them into the clipboard, revit crashes. Is this the same problem?
do you have an idea how i can go round ths problem? Is the a better way to copy the elements to the current file?
thanks
Mark
