Revit API Links Positioning
mahmoudelrawi
mahmoudelrawi
Hello all,
Does anyone knows if Revit API supports positioning for linked models (center to Center or Base Point to Base Point)?
I am working on Revit 2019.
architect.bim
Hi!
When you place new RevitLinkInstance you need to use this overload of Create methor. The third argument is ImportPlacement  Enumeration. Using it you can specify necessary type of placement.
Maxim Stepannikov | Architect, BIM Manager, Instructor
mahmoudelrawi
Hi
When I make positioning Cenetered or Site , got this massage from reviterror placement.png
architect.bim
Oh I see. Create method really supports only Origin and Shared placement, sorry for the inaccuracy. In case of base point you can try to place link with Origin Enumeration. And then call MoveBasePointToHostBasePoint method. In case of "center" actually I don't know any working solution.
mahmoudelrawi
thanks Maxim for your response, now i got it
