Revit API installation issue
I installed Revit SDK 2013, but I could find this Addin from my Revit 2013. I have no idea about this. my computer is 64bits windows 7. Does anyone give me guide on what wrong it is?
Thanks for your time
Jason
saikat
Hi Jason
Once you install the SDK, you will find that there are Samples that are contained in the SDK. The specific samples (addins) can be loaded into Revit by placing the .addin manifest file that is contained in each sample folder to some specific locations based on the OS. If you wish to load up all the SDK samples, the following blogpost should be of help:
http://thebuildingcoder.typepad.com/blog/2012/04/developer-center-and-sdk-update.html
And while you are getting started with Revit API the following two links should be useful:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16777469
http://usa.autodesk.com/adsk/servlet/index?id=2484975&siteID=123112
cheers
Saikat Bhattacharya
Senior Manager - Technology Consulting
