Revit API Connect Ducts with fitting
Hello, I have 2 Ducts and I want to connect them with a fitting. Howcan I do that. I'am searching for that since a week but I couldn't find anything.
I use this code to get the connectorset but I don't understand how to get the Connectors from it:
 public static ConnectorSet GetConnectors(Element element)
            if (element == null) return null;
            FamilyInstance fi = element as FamilyInstance;
            if (fi != null && fi.MEPModel != null)
                return fi.MEPModel.ConnectorManager.Connectors;
            MEPSystem system = element as MEPSystem;
            if (system != null)
                return system.ConnectorManager.Connectors;
            MEPCurve duct = element as MEPCurve;
            if (duct != null)
                return duct.ConnectorManager.Connectors;
            return null;
Can anyone provide me some help with that?
jeremytammik
You need to hone your searching skills a bit.
Have you ever heard of Internet search engines?
https://duckduckgo.com/?q=revit+api+connect+duct+fitting
In addition, my own favourite place to go for this topic is the series of articles on creating a rolling offset:
http://thebuildingcoder.typepad.com/blog/2014/01/final-rolling-offset-using-pipecreate.html
It is for pipes, but the same also applies to ducts.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Have you used Revit Lookup?
https://github.com/jeremytammik/RevitLookup
Browsing and testing this AddIn is invaluable if you're learning to develop in Revit.
