Revit API 2025
Revit API 2025
csuarezUPUMF
Observer Observer
Revit API 2025
csuarezUPUMF
Observer
Observer
Run button in macro manager does not activate, after I write a code. I can´t run the macro. I use Visual studio Code
Mohamed_Arshad
Hi @csuarezUPUMF
You need to select the macro instead of module, then it will activated. Kindly check the below GIF for additional reference.
Sample (.gif)
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
csuarezUPUMF
Observer
Observer
Yes, I do that in 2021 to 2024 versions, but I currently use 2025 version it´s not the same
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @csuarezUPUMF ,
I opened the macro in Visual Studio Code and wrote the following code.
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace HelloWorld
   [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
   [Autodesk.Revit.DB.Macros.AddInId("4886F77D-6046-4C75-9845-0BC125EC75FA")]
   public partial class ThisApplication
      private void Module_Startup(object? sender, EventArgs e)
      private void Module_Shutdown(object? sender, EventArgs e)
      //Comment out below method to add a sample Macro
      public void SampleMacro()
         TaskDialog.Show("Title", "Hello World");
I have a method called SampleMacro(). After navigating to the terminal in VS Code and running dotnet build, the solution built successfully, and I could see SampleMacro in the Macro Manager in Revit.
I believe the reason your macro method is not visible in the Macro Manager is that the code may have been written inside Module_Startup() or Module_Shutdown(). Code in these methods runs automatically when Revit starts or closes, rather than appearing as a selectable macro.
To make your method visible in the Macro Manager, you should create it as a separate method. This way, it can be executed directly from the Macro Manager, similar to how an IExternalCommand works.
Could you please try placing your code in a separate method, similar to SampleMacro(), and let me know if it becomes visible?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
