Architectural Default Template Missing
11075333
11075333
I am missing the architectural default template.
  • I have tried downloading the US English Residential Content Pack v1 for Revit 2026, which I'm not sure if it contains or not, but it is the closest thing I could find.
  • I've checked in my C drive under English Imperial, and it just doesn't seem to be there, but I believe it is the only template with the Exterior Wall Exterior - Split Face and CMU on MTL. Stud wall type which I need for a school project.
Does anybody know how I can get access to this template?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @11075333 ,
Your issue does not appear to be related to the Revit API. It seems that no programmatic actions are being performed via the Revit API in your case.
Please note that this discussion forum is specifically dedicated to programming and developing with the Revit API. For questions related to product setup, optimization, usage, best practices, or other end-user support issues, you are likely to receive more appropriate guidance in one of the non-API Revit product support forums.
Please take a look at this link: https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-no...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
