Revit 2026 API - document.Create.NewDetailCurve(view, spline) return null while Element is created
corentin216
Observer Observer
corentin216
Observer
Observer
So I've been using the Revit 2026 API ( and .NET ) to make QoL stuff in an addIn.
I wanted to create some Bezier Curves (HermitSplines) and store the newly created element for later use.
Here is the function I use :
        public DetailCurve CreateBezierCurve(Document document, List<XYZ> points, XYZ tangent0, XYZ tangent3)
            DetailCurve result;
            var view = document.ActiveView;
            HermiteSpline spline = HermiteSpline.Create(
                points,
                false,
                new HermiteSplineTangents()
                    StartTangent = tangent0,
                    EndTangent = tangent3
            using (Transaction tx = new Transaction(document, "Create Bezier Curve"))
                tx.Start();
                result = document.Create.NewDetailCurve(view, spline);
                tx.Commit();
            return result;
The official api info and the IDE helper tab state that the output is indeed a DetailCurve.
It also state that it can return null if a crash appears internally. however I do get the curve created in my file and no sign of any error.
I wonder if this is some bug in the API, or a mistake in the documentation. I could not find anything on that subject.
Any help or info is welcome. Thanks
PS: I know I could find that newly created curve in other ways but it is definitly not as clean as the intended way.
For instance the said curve after creation :
ctm_mka
instead of forcing it to be a Detailcurve, (which if i'm reading correctly is the issue?) try adding it to a ElementId collection using a DocumentChangedEventArgs event. Then, after committing, _doc.getelement from that collection, and return that instead. something like this:
//in your main method:
 List<ElementId> ElemIdCol = new List<ElementId>();
uiapp.Application.DocumentChanged += new EventHandler<DocumentChangedEventArgs>(OnElemCreation);
CreateBezierCurve()
var thecurve = ElemIdCol.Select(x=> doc.GetElement(x)).FirstOrDefault();
 private void OnElemCreation(object sender, DocumentChangedEventArgs e)
     ElemIdCol.AddRange(e.GetAddedElementIds());
corentin216
Observer
Observer
I guess that works I'll try to do something similar for now, Thanks !
But still I find it strange that a function like this one
DetailCurve NewDetailCurve(View view, Curve geometryCurve);
returns null while creating the curve in revit and not giving any information about an internal error or mistake...
could that be some kind of bug of revit API?
