Revit 2025 - Macro Manager and Visual Studio 2022
ricaun
Advisor Advisor
Message 1 of 10
ricaun
The Macro Manager changed in Revit 2025, now you need to have .NET SDK 8.0 and Visual Studio Code installed on your machine to create and build the macro in C#.
I found a way to use Visual Studio 2022 (which should also work with Rider) instead of using Visual Studio Code.
You need to change the configuration in the Macro Manager and add a custom code.cmd (https://gist.github.com/ricaun/482edc40d2b680ab733e12492264fd0d).
The code.cmd file finds the .csproj in the folder and tries to open it.
This should work without Visual Studio Code installed on the machine. 😁
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Replies (9)
Message 2 of 10
ankofl
Oh! Perfectly!
Thank you very much!
Message 3 of 10
rawava1350
Great, wish this was the default, with no restrictions on IDE usage. Not every developer likes VS Code
Message 4 of 10
jeremy_tammik
Congratulations on discovering this and thank you for sharing! I added it to today's blog post:
Message 5 of 10
josborneW959Y
Cool! Is there any way to get the extension to enable debugging?
Message 6 of 10
ricaun
Sure: https://github.com/ricaun-io/RevitAddin.VisualStudioDebug
Message 7 of 10
Eduardo.SaezDRTV4
So from Revit 2025 coding has to be in C#, there is no way to code in VB or Python ?
Message 8 of 10
jeremy_tammik
No. The Revit API is based on .NET.
You can use any language that can connect appropriately to the Revit .NET API framework.
Message 9 of 10
Eduardo.SaezDRTV4
Thought so, just wanted to confirm.
So guess I need start learning C# then and quickly
Thanks Jeremy
