【Revit 2025 API】 A Question about SetFormula
yz8023yz
yz8023yz
When I execute the following code
FamilyManager manager = familyDoc.FamilyManager;
ForgeTypeId forgeTypeId_length = new ForgeTypeId("autodesk.spec.aec:length-2.0.0");
FamilyParameter parameter_qzh = manager.AddParameter("墙肢高度", GroupTypeId.Geometry, forgeTypeId_length, false);
I got this
But when I execute this one code:
manager.SetFormula(parameter_qzh, "侧墙高度 -底板厚度");
it will throw an error:There is no valid family type. at Autodesk.Revit.DB.FamilyManager.SetFormula(FamilyParameter familyParameter, String formula)
TripleM-Dev.net
Is there a Type active in the FamilyEditor, a parameter needs to be set while a type is set.
If no types are defined (the type box shows a grey inactive combobox) the values can't be set.
See remarks in: CurrentType
I Think the UI can do this because it sets the type to the name of the family...
- Michel
yz8023yz
Hi, thanks for the reply, but I noticed that the type box is not showing the gray inactive combo box.screenshot-1719884883577.pngscreenshot-1719884941798.png
yz8023yz
Add the following code for the creation parameter in the family document
// Checks to see if the current family type exists, and if not, creates the
FamilyType currentType = manager.CurrentType;
if (currentType == null)
currentType = manager.NewType("DefaultType");
