Revit 2024 'Other' Parameter Group
kevin_fielding
kevin_fielding
With the change over to ForgeTypeId and GroupTypeId in Revit 2024 instead of BuiltInParameterGroup enumerations, I just wanted to share how to define the 'Other' group for parameters as it doesn't appear to be documented.
Whereas previously you would use
BuiltInParameterGroup.INVALID
In 2024 and beyond you need to use
new ForgeTypeId(string.Empty)
Other groups can be found using the GroupTypeId class like GroupTypeId.Data
Hope this helps others searching for this.
Kevin
jeremy_tammik
Thank you for the very useful hint!
jeremy_tammik
andrea.tassera
Sorry for reviving an old post.
Apparently using new ForgeTypeId(string.Empty) only works for Revit 2024 and above. I was just testing what's on this post in my code and it was working with Revit 2025, but not in Revit 2023.
The ForgeTypeId change seems to be applied from Revit 2021 onwards so I thought it was strange that it wasn't working in 2023. I did some experimentation and if you use null instead of new ForgeTypeId(string.Empty) then it works in all versions of Revit.
Thought you guys might be interested 😉
niklas_portmann
Hey all, sorry again for reviving this.
It seems that the ParameterBindings.ReInsert(definition,binding,new ForgeTypeId("")) method will actually not update the parameter group and just keep it as the same parameter group as before. That means once you've set the parameter group to any non-empty type id it's impossible to reset it to the "Other" parameter group?
I also tried with ParameterBindings.ReInsert(definition,binding,null) but it had the same effect.
Does anyone of you have a workaround for this or am I just missing a piece of information here?
