revit 2024 not finished downloading
adrianTD9JY
adrianTD9JY
Community Visitor
Community Visitor
I stopped downloading revit 2024 because it stalled at 97%. I thought i had bad wifi connection. I tried to download it again and it said it could not download because it is already installed.. i can't find it and how can i uninstall to reinstall?
jeremy_tammik
Normally, the Windows OS will offer you the option to uninstall.
In any case, this is not the optimal place to discuss such an issue. Please note that this discussion forum is dedicated to programming Revit using the Revit API. I am afraid you cannot expect an optimal answer to a question like yours relating to product setup, optimisation, usage, or other end-user support issues here. You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
