Dark Theme Icons - a couple of hacks
matthew_taylor
Advisor Advisor
matthew_taylor
Hello all,
I've implemented something similar to what @jeremy_tammik shows here: https://thebuildingcoder.typepad.com/blog/2023/01/dark-theme-possibility-looming.html
Hack 1:
I've long used .bmp files as my raw ribbon icon images.
I take those .bmp files and create .png files using a program called ImageMagick (https://imagemagick.org - I'm not affiliated).
Once installed you may use it in batch scripts etc:
https://imagemagick.org/script/command-line-processing.php
https://imagemagick.org/script/command-line-options.php
This what I used in Revit 2023:
rem For each .bmp file in this folder,
rem   convert the white pixels to transparent,
rem   and save the result to .png.
for %%f in (*.bmp) do ( convert -transparent white %%f %%~nf.png)
Then with Revit 2024, the Dark theme came along!
This is what I ended up with, in addition to the above:
rem   invert the grayscale pixels only (white->black, lightgray->darkgray, darkgray->lightgray, black->white etc etc)
rem   convert the black pixels to transparent,
rem   add 30 to each R,G,B value (necessary as our dark mode is not black - this is an arbitrary value to lighten the overall image),
rem   and save the result to _dark.png.
for %%f in (*.bmp) do ( convert +negate -transparent black -colorize 30,30,30  %%f %%~nf_dark.png)
This system works well with grayscale icons, and icons that already used a similar colour scheme to native Revit.
I imagine it's possible to use the -scale switch to create 16x16 icons from 32x32 icons, but I've not tested that.
I imagine it's also possible to add badges (from the zip in Jeremy's post) to images using something like this: https://stackoverflow.com/questions/11095007/add-an-image-on-top-of-existing-one-with-imagemagick-co...
Hack 2:
Another issue I had was that I was using icons as embedded resources.
I couldn't work out how to get the name of the icon from the ribbon item Image or LargeImage property in order to get the dark or light equivalent. (I was changing the icons in the ThemeChanged event.)
I worked out I could embed the name within the BitMapSource when initially adding the image:
Private Shared Function GetEmbeddedImage(ByVal assembly As Assembly, ByVal imageFullName As String) As BitmapSource
  If Not String.IsNullOrEmpty(imageFullName) Then
      Dim s As IO.Stream = assembly.GetManifestResourceStream(imageFullName)
      If s IsNot Nothing Then
          Dim bitmap As BitmapSource = BitmapFrame.Create(s)
          Dim metadata As BitmapMetadata = New BitmapMetadata("png")
          metadata.SetQuery("/iTXt/Keyword", imageFullName.ToCharArray())
          Dim bitmapWithMetadata As BitmapSource = BitmapFrame.Create(bitmap, Nothing, metadata, Nothing)
          Return bitmapWithMetadata
  Return Nothing
End Function
I could then retrieve that name:
Dim ribbonItem as RibbonItem...
Dim bitmapSource As BitmapSource = CType(ribbonItem.Image, BitmapSource)
Dim metadata As BitmapMetadata = CType(bitmapSource.Metadata, BitmapMetadata)
If metadata IsNot Nothing Then
   Dim existingValue As Object = metadata.GetQuery("/iTXt/Keyword")
   Dim imageName As String = TryCast(existingValue, String)
   'Use image name to get an embedded resource and set it to the ribbon item image.
I hope this saves some of you a bit of time and effort.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
moturi.magati.george
Hi @matthew_taylor,
Thank you for your workaround on the dark theme.
You can also submit your solution in the Revit Idea Station or add to the corresponding wish list entry for the suggested functionality and add your comments to it:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team look there. Your comment here in the discussion forum might be overlooked.
  Moturi George,     Developer Advocacy and Support,  ADN Open
matthew_taylor
Thanks @moturi.magati.george , but the API was fine in this case. 😀
Cheers,
-Matt
jeremy_tammik
Dear Matt,
Thank you very much for sharing your useful hacks! I added them to the blog as well for wider visibility:
https://thebuildingcoder.typepad.com/blog/2023/05/dark-icons-newfamilyinstance-and-ai-news.html#2
Cheers,
Jeremy
