Revit 2024.2 Dark Mode automatic color conversion
andris19980330
andris19980330
Hello!
I'm using Revit 2024.2 and can I disable the automatic color conversion in dark mode somehow? 😞
All the colors are different in dark mode.
thanks!
jeremy_tammik
This sounds like an end user interface question to me, not related to programming yourself using the Revit API. Hence, I am afraid this is the wrong place to raise it.
Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query/description and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are better equipped to address this topic than us programming nerds.
I hope this clarifies. Thank you for your cooperation and understanding.
Best regards,
Jeremy
andris19980330
I cannot find a single forum for Revit interface, so I opened my problem here. Sorry for this. Could you or someone move my topic there?
andris19980330
andris19980330
jeremy_tammik
No problem, not to worry. Generic Revit UI issues are mostly discussed in the most generic and largest Revit forum, which is the architectural one, afaik.  I am not an admin here, so I cannot help. You could just create a new thread there, if you like, and we can close this one off.
