Revit 2022 Default Library
Hi everyone,
I am a student and downloaded Revit 2022 for school, but nothing my professor was using was on my version. So I went and downloaded the Revit 2022 content from here:
I have more options now, but still not the ones my professor was using. An example of a wall type I'm looking for is "Basic Wall Exterior - Brick on CMU".
Any help would be greatly appreciated!
Thanks!
AGGilliam
A couple things;
First of all, this is the API forum, your question would likely get a better response from the Architecture forum.
Second, I can tell you that walls aren't loadable families so you won't find any wall types in a library. I would recommend taking another hard look at the types you have to choose from when placing a wall, the type itself is "Exterior - Brick on CMU" and it will be listed under the Basic Walls (as opposed to a curtain wall).
If you still can't find it, you could make a post in the other forum or ask your professor for the information to make your own wall type.
Thank you so much! Sorry, I'm still very new to all the software and language, and I wasn't sure where to post.
AGGilliam
No worries! I assumed as much, each forum is just better suited to a specific area of the software. The API forum is full of programmers so we might not be able to answer a question like that as well as someone from the Architecture forum who is regularly using those tools. Best of luck!
