Revit 2019 can't run external applicatins
不适用
447 次查看
2 条回复
1 条消息(共 3 条)
不适用
0 个赞
已接受的解答 (1)
448 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
naveen.kumar.t
Autodesk Support
Autodesk Support
已接受的解答
Hi @Anonymous ,
I think there are some problems with your .addin manifest file
1)Check whether you gave proper class name. For example
namespace REVITAPPLICATION
    [Transaction(TransactionMode.Manual)]
    public class Class1 : IExternalApplication
then the FullClassName should be
<FullClassName>REVITAPPLICATION.Class1</FullClassName>
2)Since you created an application, in the Addin manifest file the ADDIN type should be application
     <AddIn Type="Application">
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
0 个赞
3 条消息(共 3 条)
不适用
Thanks for your help. I find my fullclassname is wrong. Letters should be case-sensitive.
0 个赞
