Revit 2017 - Simple Dockable Pane using C# - Blank page?
mileta_pejovic
mileta_pejovic
Thanks on all great posts on the forum which helped me to start entering into Revit API world 🙂
At the very beginning I have a problem with Dockable panel created for revit 2017.
The problem is shown in the attached picture (blank/black dockable panel space even though I created page.xaml)
What do I do wrong?
Here's the code for App:
namespace DockTest
class App : IExternalApplication
public Result OnStartup(UIControlledApplication a)
//TODO: Register dockable panel "Test".
Test page1 = new Test();
DockablePaneId paneId = new DockablePaneId(new Guid("9d7ed357-534f-4d87-afc4-8e784e3b119e"));
a.RegisterDockablePane(paneId, "Test", (IDockablePaneProvider)page1);
return Result.Succeeded;
public Result OnShutdown(UIControlledApplication a)
and this is the code for .xaml:
<Page x:Class="DockTest.Test"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:local="clr-namespace:DockTest"
mc:Ignorable="d"
d:DesignHeight="300" d:DesignWidth="300"
Title="Test">
<Grid Background="#FFE1E1E1">
<Grid.RowDefinitions>
<RowDefinition Height="Auto"></RowDefinition>
<RowDefinition></RowDefinition>
</Grid.RowDefinitions>
<Grid.ColumnDefinitions>
</Grid.ColumnDefinitions>
<Label Grid.Row="0">Log</Label>
<StackPanel Grid.Row="0">
<Button Name="checkAllButton" Click="checkAllButton_Click">Check All</Button>
<Button Name="checkNoneButton" Click="checkNoneButton_Click">Check None</Button>
<Button Name="okButton" Click="okButton_Click">OK</Button>
<Button Name="cancelButton" Click="cancelButton_Click">Cancel</Button>
<Button Name="isolateButton" Click="isolateButton_Click">Isolate</Button>
</StackPanel>
<TextBox Name="tb_output" Grid.Row="1" VerticalScrollBarVisibility="Visible" HorizontalScrollBarVisibility="Visible" TextChanged="tb_output_TextChanged"/>
<Label Content="Project Name:" Grid.Row="2" Height="28" HorizontalAlignment="Left" Name="lblProjectNameHeading" VerticalAlignment="Top" Margin="-1,6,0,0" />
<Label Content="Label" Grid.Row="2" Height="26" HorizontalAlignment="Left" Margin="76,6,0,0" Name="lblProjectName" VerticalAlignment="Top" Width="114" />
</Grid>
</Page>
code for xaml.cs:
namespace DockTest
/// <summary>
/// Interaction logic for Test.xaml
/// </summary>
public partial class Test : Page, IDockablePaneProvider
public void SetupDockablePane(DockablePaneProviderData data)
data.FrameworkElement = this as FrameworkElement; ;
data.InitialState.DockPosition = DockPosition.Tabbed;
//data.InitialState.TabBehind = Autodesk.Revit.UI.DockablePanes.BuiltInDockablePanes.PropertiesPalette;
data.InitialState.TabBehind = Autodesk.Revit.UI.DockablePanes.BuiltInDockablePanes.ElementView;
private void checkAllButton_Click(object sender, RoutedEventArgs e)
private void checkNoneButton_Click(object sender, RoutedEventArgs e)
private void okButton_Click(object sender, RoutedEventArgs e)
private void cancelButton_Click(object sender, RoutedEventArgs e)
private void isolateButton_Click(object sender, RoutedEventArgs e)
private void tb_output_TextChanged(object sender, TextChangedEventArgs e)
Thanks in advance,
Mileta
Hi Mileta,
The page is displaying as blank because you've not initialised the components in your class file.  You can fix it by adding a call to InitializeComponent();
For example:
        // Initialize Components
public Test() { InitializeComponent(); } public void SetupDockablePane(DockablePaneProviderData data) { ... }
Hopefully this should get you up and running.
Cheers,
Adam
mileta_pejovic
Thanks a lot, all is working now
As I said, just starting with Revit API and C# and all posts on the forum are more than helpful.
