Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
dimmension end of wall
1 REPLY 1
sonicer
262 Views, 1 Reply
still can't make dimmension if the wall is not paralel?
1 REPLY 1
FAIR59
in reply to: sonicer
the "endpoint" reference of a wall has ElementReferenceType.REFERENCE_TYPE_SURFACE,
so the dimension has to be parallel to the wall.
You can however dimension the Edges of the wall with a dimension non-parallel to the wall.
Here is some code that works in planviews:
            ReferenceArray refArr = new ReferenceArray();
            List<GeometryObject> geoObjects = GetGeometryObjects(_wall);
            foreach (GeometryObject obj in geoObjects)
                Solid solid = obj as Solid;
                if (solid == null) continue;
                foreach (Face _face in solid.Faces)
                    if (Math.Abs(_face.ComputeNormal(new UV(0, 0)).Z) < 0.0001)
                        foreach (EdgeArray _edgeArr in _face.EdgeLoops)
                            foreach( Edge _edge in _edgeArr)
                            XYZ direction = _edge.ComputeDerivatives(0).BasisX.Normalize();
                            if (direction.IsAlmostEqualTo(XYZ.BasisZ) || direction.IsAlmostEqualTo(XYZ.BasisZ.Negate()))
                                refArr.Append(_edge.Reference);
                                if (_edge.Reference == null) continue;
                    if (refArr.Size > 1) break;
            XYZ dimDirection = new XYZ(1, 1, 0);
            LocationCurve lc = _wall.Location as LocationCurve;
            XYZ startPoint = lc.Curve.GetEndPoint(0);
            using (Transaction t = new Transaction(document, "dimension_wallEnd"))
                t.Start();
                // create dummy line to "lock" the direction of dimensionline
                DetailCurve dummy = document.Create.NewDetailCurve(document.ActiveView, Line.CreateBound(startPoint, startPoint.Add(dimDirection.CrossProduct(XYZ.BasisZ))));
                refArr.Append(dummy.GeometryCurve.Reference);
                Dimension dim = document.Create.NewDimension(document.ActiveView, Line.CreateBound(XYZ.Zero, dimDirection), refArr);
                sb.AppendFormatLine("{0}", dim.Id);
                document.Delete(dummy.Id);
                t.Commit();
