Revit 2013 PickObject
The API PickObject function doesn't work anymore with Revit 2013.
I tried to edit the code with help of the migrating blog post of Jeremy's, but without succes.
This is the code:
                        SheetFilter selFilter = new SheetFilter();
                        Selection sel = uiapp.ActiveUIDocument.Selection;
                        pickedRef = sel.PickObject(ObjectType.Element, selFilter, "Select sheet.");
                        Element elema = pickedRef.Element;
 Its the pickedRef.Element; wich gives me an error.
Does someone know how to fix this?
Thanks!
Joost
Revitalizer
Hi Joostschlebaum,
in Revit 2011 and 2012, yourReference.Element can be used,
in 2013, you need to use
yourDocument.GetElement(yourReference.ElementId).
Cheers,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hi Revitalizer,
That's the key! Awesome!
Thank you very much sir!
