Revision Schedule Line weight displayed differently from titleblock's.
Dear Revit Masters,
Here's my problem: I set up the line style and line weight carefully in my project, but it turned out the line weight of the REVISION SCHEDULE is thicker than other lines in the TITLEBLOCK. (image 1).
Both the Title Block and the Revision Schedule are using the same line (image 2 & 3), which is "Medium Line" I defined, using "Line Style 4" at 0.9mm weight (image 4 & 5).
Many thanks in advanced.
Harry
image 1image 1
image 2image 2
image 3image 3
image 4image 4
image 5image 5
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Are you doing this using Revit API?
This forum is only for Revit API questions.
For non-API questions, please choose another forum that is more appropriate.
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not-for/td-p/5607765
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
