return to main project
Message 1 of 19
I have the following situation.
I am in a project and I create a new family. After I save the family and close it, I am back in my project file, BUT my ribbon is the ribbon of the family editor (with "create" and not "Architecture"as first panel). It looks like revit still thinks I am in the family.
My question is how can I save the family and return to my project with it's own ribbon ?
My code looks something like this :
Document ProjectDoc = commandData.Application.ActiveUIDocument.Document; //main project I start in
Document fdoc = commandData.Application.Application.NewFamilyDocument(templateFileName); //make new family
// make the most beautifull family you'd ever seen with sweeps, extrusions ect.
SaveAsOptions opt = new SaveAsOptions();
opt.OverwriteExistingFile = true;
fdoc.SaveAs(sfd.FileName, opt);
commandData.Application.OpenAndActivateDocument(ProjectDoc.PathName); //make project active again (If I check active document is project)
fdoc.Close();
My ribbon stays the one of the family editor, it even has the "Load family into project" button, which tells me "There are no other projects open to load this project into".
Does anybody know how to get my project ribbon back ? Or what I am doing wrong because apperently revit somehow is under the impression the family document (fdoc) is still opened ??
Replies (18)
Message 2 of 19
gopinath.taget
I did a little bit of research and do not see any problems with your code. The following blog post for instance has very similar code to yours:
http://thebuildingcoder.typepad.com/blog/2011/06/creating-and-inserting-an-extrusion-family.html
I dont see any reports about the ribbon context not changing. Do you see the ribbon stay the same even if you are working with elements in the current project?
Best Regards
Gopinath
Message 3 of 19
It's strange. Everything is normal, until I use the code to make a family. Sometimes the first time the ribbon is okay, but when I run the code a second time, the ribbon stays as if you are working in the family editor... I will try another computer later on.
Message 4 of 19
jeremytammik
Dear Remy,
Did you get this resolved?
If not, can you please confirm that you are indeed using the latest update release?
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 5 of 19
Joe.Ye
As I know there is a exception with the Ribbon. This exception can be fixed by install the web update of Revit 2014. Would you please install the latest Revit update to see if this can be fixed? Update can be download in this page. (http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=21208796)
Joe Ye
Contractor
Message 6 of 19
Hello jeremy, the problem is still there 😞
Everytime I run the code above, the ribbon changes from the Project ribbon to the family editor Ribbon and statys this way until I close the current project and open it (or another project) again.
I'm using version :
20131024_2115(x64)
Update Release 2
Windows 8 64 bits
Message 7 of 19
The Page You Requested Was Not Found
Message 8 of 19
jeremytammik
Remove the closing parenthesis:
Unfortuneately, that just lists the update releases.
It does not mention this specific issue, as far as I can see.
However, I do also seem to remember seeing this problem mentioned before and resolved by an UR.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 9 of 19
Well I know issues with the ribbon related to in installation of revit LT next to Revit, bu in my case everything works normal, until I use the code above. It's like the family is being created in the background, and after the family is saved, the family document isn't properly closed and statys open.
Message 10 of 19
jeremytammik
Dear Remy,
Maybe it will help if you can add some suitable code to explicitly cose the family document a bit more, or switch back to the main document a bit more, or add some more transactions, or a transaction group, or something, to definitly force Revit into a stable settled state and really forget about the family for good.
Does the code that Joe pointed to do that successfully for you?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 11 of 19
Hi Jeremy,
I don't see whats different about the Code Joe pointed out and mine. I tried some extra transactions, no result. Is there some kind of way I can refresh or address a certain ribbon panel ?
Message 12 of 19
Revitalizer
Hi Remy,
I faced a similar problem some time ago.
In the case that my familiy creation has failed, there was a document with no active View still opened in Revit.
This document caused Revit not to show the start screen that should appear in a non-document environment.
Also, ribbon didn't change but remained in family context.
I worked around this by closing all documents which have no active view and whose names begin with "Family" respectively "Familie" after doing my family creation stuff.
Thus, all *failed* new families with temporary names like "Family 1", "Family 2" etc. are removed from application.
Since my (successfully) newly created Family has a different name than "Family XY", it is not affected by this workarounding.
May this help you ?
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 13 of 19
Your idea gave me an idea 🙂 I thought, let's see what documents revit thinks are still open after I created the family. So I am in a project, create the family and then use "snoop Application" with revit lookup, I get a .NET error saying "the managed object is not valid". Weird..
Message 14 of 19
Well, I am one step closer .. Now snoop doesn't crash anymore and I can see nly one document open (so the created family document is indeed closed). Although I set my project back as active document, even "captured" the active view before creating the family, and afterwards the the active view back to the original. Nothing helps 😞  The ribbon stays like in a family document.
No here is the crazy thing, when I am in this "family ribbon" state and I now open revit lookup, choose Snoop application and click on Documents, my ribbon comes back ??
Message 15 of 19
jeremytammik
Dear Remy,
Please debug.
Please debug, fix it, and submit the fix to GitHub:
https://github.com/jeremytammik/RevitLookup
Please debug and examine what is going on.
RevitLookup is an external application, you have all the source code, everything that it does you can do in your own add-in as well.
Please base your exloration on the most up-to-date version:
Many thanks to Revitalizer for his valuable experiences, creative ideas and helpful hints!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 16 of 19
Hello Jeremy, I think you misunderstood me. I hven't found a bug in Revit lookup! The problem I have is I am making a new family through the APi and when I saved the family and close the document, the ribbon stays in "family editor" mode, even when I set my project file active. For an example I gave Revit lookup, since by the procedure I described, suddenly my ribbon is back to "project" mode. I still haven't found out why the ribbon stays in family mode, and why it suddenly changes back to "project" mode, when I use revit lookup.
Message 17 of 19
jeremytammik
Dear Remy,
Thank you for your update.
I was simply referring to your statement that "I get a .NET error saying 'the managed object is not valid'" and later that "snoop doesn't crash anymore". The reason for such behaviour can be determined using the debugger, and an exception handler added to avoid it.
You don't say whether you were able to successfully make use of the valuable suggestions by Revitalizer... how did it go?
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 18 of 19
Tried it, same result 😞 But I am still testing. It seems when I use the code for making 1 family, the ribbon behaves normally. When I use the code to make several families in a loop, it goes wrong. As soon as I solved it, I will post.
Message 19 of 19
cig_ad
Hi Remy,
did you resolve this? I seem to have the same problem. - thanks, Peter
