Return Revit Model linked to a project
pmcmm1
pmcmm1
Dear colleagues,
I'd be surprised if this question hasn't been answered yet in this forum. Yet, I wasn't able to find the exact answer to what I'm looking for. So, in first place, excuse the redundancy if that's the case.
I want to obtain the linked revit models that are linked to an open document. I've used the following line
DocumentSet docs = commandData.Application.ActiveUIDocument.Document.Application.Documents;
to retrieve a DocumentSet containing all the documents open in revit. Then I iterated through the documents and used the Property doc.IsLinked to check if that document is linked.
However, if I have two models open in revit and both have linked models, my code will return the linked models of both files. How can I make sure that only linked files from my document get returned?
jeremytammik
Install RevitLookup. Look at the database contents. In the document containing links, you will see RevitLinkInstance entries representing the linked files. You can retrieve all those entries using a filtered element collector.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
pmcmm1
Thank you once again Jeremy. For reference, this is the little function I wrote to retrieve all linked documents
public static List<Document> GetLinkedDocuments(Document doc)
            var fc = new FilteredElementCollector(doc)
                .OfCategory(BuiltInCategory.OST_RvtLinks)
                .WhereElementIsNotElementType();
            var list_docs = new List<Document>();
            foreach (var elem in fc)
                RevitLinkInstance link = (RevitLinkInstance)elem;
                Document link_doc = link.GetLinkDocument();
                list_docs.Add(link_doc);
            return list_docs;
jeremytammik
Cool.
Thank you for your appreciation.
Here is a slightly more succinct and efficient version that does not construct a new List object:
    IEnumerable<Document> GetLinkedDocuments(
      Document doc )
      return new FilteredElementCollector( doc )
        .OfCategory( BuiltInCategory.OST_RvtLinks )
        .Cast<RevitLinkInstance>()
        .Select<RevitLinkInstance, Document>(
          link => link.GetLinkDocument() );
I also added it to The Building Coder samples for future reference.
Can you confirm that it works as well, please?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
