Return ConduitRun Elements
aaronR7JP6
aaronR7JP6
Long story short, I want to access all conduit elbows in each conduit run on a sheet so I can determine the amount of bend in each run. I can get access to the conduit runs, but I am unable to access each element (conduit) that makes up the run. I'm new to the API so maybe there' an easy solution to this. I have tried GetDependentElements and GetGeneraingElementIds but I'm unsure of he syntax to properly use those methods, or even if those are the correct methods to use. I am using pyRevit to code:
    # Collect conduit runs in the selected view
	conduit_runs_collector = DB.FilteredElementCollector(revit.doc).OfClass(DB.Electrical.ConduitRun)
	conduit_runs = conduit_runs_collector.ToElements()
    # Analyze each conduit run
	for conduit_run in conduit_runs:
		print(conduit_run)
		total_bend_angle = 0
		for element in conduit_run:
			print(element)
sstewartPHEFA
I haven't tried this myself, but I imagine the GetSubelements method would return all the items in the ConduitRun. From there you can filter through, find the bends, their angle parameter, and then add it all together.
nobre_fs
I don't know if this is what you want, but here is an idea.
I've made two filters: the first one is to get every ConduitRun and the other is to get every ConduitFitting.
With the ConduitRun, a dict was created with each ConduitRun's Id as key and initializing with 0.
Then, for each ConduitFitting, get the associated ConduitRun. I did not find a direct way to get this. There are comments in the code to explain the process. Then, get the angle from the fitting and add it to the dict.
conduit_runs_list = FilteredElementCollector(doc).OfClass(Electrical.ConduitRun).WhereElementIsNotElementType().ToElements()
conduit_runs_dict = {conduit_run.Id:0 for conduit_run in conduit_runs_list}
conduit_fittings = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ConduitFitting).WhereElementIsNotElementType().ToElements()
for conduit_fitting in conduit_fittings:
    mep_model = conduit_fitting.MEPModel # MEPModel associated to the fitting
    connector_manager = mep_model.ConnectorManager # ConnectorManager from the MEPModel
    if connector_manager:
        # From here, a conduit fitting has two connectors, one in each end
        # first we get the connectors and then the connectors that it is connected to
        # then we get the conduit that has the connector that the fitting is connected to
        # finally, the ConduitRun for that conduit
        connectors = list(connector_manager.Connectors) # All Connectors (ConnectorSet class) from this ConnectorManager
        connector_refs = list(connectors[0].AllRefs) # All references of the connector, i.e. elements that is connected to
        cond = connector_refs[0].Owner # Conduit which the fitting is connected to
        cond_run_id = cond.RunId  # Id of the ConduitRun (it was used as key for the dict)
		angle = conduit_fitting.LookupParameter("Angle").AsDouble() # Supposing your fitting has a parameter named Angle
        conduit_runs_dict[cond_run_id] += angle
for v in conduit_runs_dict.values():
    print(v)
