Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Retrieving useable line style
4 REPLIES 4
984 Views, 4 Replies
I was trying to retrieve useable line style(shown in combobox when we draw model or detail line) as typed below
FilteredElementCollector collector = new FilteredElementCollector(doc).OfClass(typeof(GraphicsStyle)).WhereElementIsNotElementType();
this code return so many graphicsstyle element.
i want to filter useable line style when draw line.
4 REPLIES 4
After playing a bit with RevitLookup, I've found that you need to check the ParentCategory of the GraphicStyle. In you case it should be Lines.
Try the following code. I didn't check it myself, but should work:
            var styles =
                .ToElements()
                .Where(e=>e.Category!=null
                    && e.Category.Parent!=null
                    && e.Category.Parent.Id == new ElementId(BuiltInCategory.OST_Lines));
Victor.
i was trying to your code. but return 0 result.
i changed code.
Category => GraphicsStyleCategory
var styles =
               .ToElements().Cast<GraphicsStyle>().Where(e => e.GraphicsStyleCategory != null && e.GraphicsStyleCategory.Parent != null && e.GraphicsStyleCategory.Parent.Id.Equals(new ElementId(BuiltInCategory.OST_Lines))).ToList();
this code is working. but this result is not what is expected.
That's wierd, I just executed your code and it shows me exactly what you need.
I tried in Revit 2016.
Anyway, i glad you've found the solution.
Rail Community
