Retrieve window width and height
Can somebody help me retrieve a window's width and height?
This compiles but does not work unfortunately, because it returns "False":
window.get_Parameter(BuiltInParameter.WINDOW_WIDTH).HasValue;
When I cast the parameter with AsDouble() I get 0. The variable "window" is of type "Element".
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
try using the below code
Element Window;
                FamilyInstance fi = Window as FamilyInstance;
                FamilySymbol fs = fi.Symbol;
                double height = fs.get_Parameter(BuiltInParameter.WINDOW_WIDTH).AsDouble();
                double width = fs.get_Parameter(BuiltInParameter.WINDOW_HEIGHT).AsDouble();
I hope this helps
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you so much, this finally works! Maybe you could fix the indentation (if it isn't by design) and swap the width/height variable names, so others who find this thread aren't confused 🙂
What does Element Window get? Because in my case he is saying that the variable window was never used.
jeremytammik
If you have not defined the variable `window` then it will not exist and indeed cannot be used.
Jeremy Tammik
Autodesk Developer Network, ADN Open
The Building Coder
