Hi guys,
I know this forum about Revit API but i can't find anywhere to post about help Forge API.
Sorry if it bothers.
I'm newbie in forge.
I'm trying run example of Mr.Jeremy Tammik project : Roomedit3d but can't (seem because it have new version v3)
Now, i want run project Roomedit3d but i don't know how to get urn from file.rvt manual
I do not know much about Forge so I want to test a project but can't
How can i get urn link from my file ?
Thank in advanced
Hi guys,
Thank in advanced
Solved by jeremytammik. Go to Solution.
Search for something like 'Autodesk Forge get help':
https://duckduckgo.com/?q=autodesk+for+get+help
One of the top hits will be:
https://forge.autodesk.com/en/support/get-help
Go on, try it out!
You can do it!
Yeaaaah!
Go on, try it out!
You can do it!
Yeaaaah!
For information on roomedit3d, please read all the associated blog posts on that topic, both in The Building Coder and in the 3D Web Coder blogs.
Here is the GitHub repository:
https://github.com/jeremytammik/roomedit3d
It also includes some documentation.
Above all, the documentation explains in full detail how to generate and retrieve the URN you seek.
Good luck and have fun!
Thank you Mr.Jeremy Tammik for support.
Thanks again !
Thanks again !
