Retrieve common geometry of all participants
mr.engineer.aec
mr.engineer.aec
 Hi guys,
I have faces intersect, i want retrieve common geometry of all participants.
How can i solved this issue ?
Thank in advanced.
Yien_Chao
Maybe using this function https://www.revitapidocs.com/2020/eb8735d7-28fc-379d-9de9-1e02326851f5.htm
If the element is inside 2 bounding boxes then its common.
jeremytammik
To me, it sounds as if you are looking for a 2D Boolean intersection operation.
Revit does not provide this functionality.
However, you can easily make use of other .NET libraries implementing it and reference those in your Revit add-in.
I have repeatedly made use of the Clipper library for such purposes:
The last pointer highlights the most interesting and up-to-date sample using it so far, ElementOutline:
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
mr.engineer.aec
Thank @jeremytammik
