Retrieve all parameters that can be assigned to a multi-category Schedule programmatically
 //Code to retrieve all multi-Category-Schedules
FilteredElementCollector elementCollector = new FilteredElementCollector(Common.ProjectDocument);
List<ViewSchedule> multiCategorySchedules = elementCollector.OfClass(typeof(ViewSchedule))
                 .ToElements()
                 .Cast<ViewSchedule>()
                 .ToList()
                 .Where(x => x.Definition.CategoryId.IntegerValue == -1)
                 .ToList<ViewSchedule>();
//The loop is not needed in this case because the project only has
//one multi-category - schedule, but out of habit I left it
foreach ( ViewSchedule schedule in multiCategorySchedules)
//Retireve all the unique fields for one schedule
  Dictionary<ElementId, string> availableParameters = new
  Dictionary<ElementId, string>();
  ScheduleDefinition def = schedule.Definition;
  foreach(SchedulableField p in def.GetSchedulableFields())
   if (!availableParameters.ContainsKey(parameterId))
        availableParameters.Add(parameterId, name);
Currently I am working on code that is supposed to retrieve all available parameters for a multi-category schedule. As shown the in the screenshot below ,I have four different fields available (Multiple Categories, Room, Space, Project Information) from which I can select parameters.
The code that I attached is able to retrieve all of them, however, it also retrieves about 200 more parameters that I am not able to assign to this schedule. I did check for unique element ids, however, it only eliminated a few extra parameters. Could somebody take a look at my code and help my understand if I am missing something or if the parameters that I don't seem to be able to find are hidden somewhere in Revit.
Thanks a lot in advance!
jeremy_tammik
Does the IsSchedulableField predicate help filter out the unwanted ones?
https://www.revitapidocs.com/2021.1/f08c6d5b-600d-8770-1e02-31d4c31641f0.htm
The description says, Checks whether a non-calculated/non-combined field is eligible to be included in this schedule.
Hi Jeremy,
I also added these 5 fields to my code and still don't get the exact result:
&&( p.FieldType == ScheduleFieldType.ProjectInfo
|| p.FieldType == ScheduleFieldType.Room
|| p.FieldType == ScheduleFieldType.Space
|| p.FieldType == ScheduleFieldType.ElementType || p.FieldType == ScheduleFieldType.Instance))
However, after experimenting with the "FieldType", I noticed that the additional parameters are all Instance parameters. When I filtered by every FieldType that I used above except for ScheduleFieldType.Instance, I didn't have any additional parameters, but was missing  all the  Instances.
My suspicion is that the additional parameters are Family-Instance parameters, but I am going to do a little bit more research on that.
Thanks for the hint!
