Geometry aligned Bounding Box
zrodgersTSSSU
zrodgersTSSSU
Hey everyone, I was wondering if there was a way like in dynamo to generate an align bounding box using a coordinate system? I found this and didnt know if something similar would be possible through the API.
jeremy_tammik
Not really, I'm afraid. In the Revit API, the bounding boxes are always axis aligned. That is what makes them so fast and efficient.
JeremyvU2GS6
Is this still the case now that dynamo has a Z only axis aligned bounding box? Is there an API call for that?
jeremy_tammik
Don't know about Dynamo, I'm afraid. In Revit bounding boxes are aligned with the global coordinate system three cardinal axes X, Y and Z.
jeremy_tammik
Actually, the Revit API BoundingBoxXYZ class does indeed sport a Transform property:
I have not seen it used, though. It would be interesting to see and hear about usage examples of that.
JeremyvU2GS6
Thanks for the response. I want to elevate elements (curtain walls, windows, doors) to their exterior face. I know of a dynamo method to get only Z aligned BB around geometry to get a face I can use for crop regions etc. Transform will help thanks. Well I use that bounding box and an intersection plane of the element location to ensure its front on
