RET.msi Missing when installing REVIT 2022 (The feature you are trying to use is on a network resource that is unavailable)
hhuyngoc
hhuyngoc
Hi everyone,
Does anyone know about this issue? when I reinstall REVIT 2022, the following error occurs.
Could you please help me?
Appreciate for your review and support.
moturi.magati.george
Hi @hhuyngoc,
Kindly note that this forum is only for Revit API questions.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
But I have done a quick search for you and found the following links that might be of help.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-feature-you-ar...
  Moturi George,     Developer Advocacy and Support,  ADN Open
