Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Result Execute error CS0161, not all code paths return values
3 REPLIES 3
jw.vanasselt
347 Views, 3 Replies
jw.vanasselt
Hi all,
I just started to create one of my first scripts but I have an error on the Execute row.
using System;
using System.Collections.Generic;
using System.Net;
using System.Windows.Markup;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Reference = Autodesk.Revit.DB.Reference;
namespace MyRevitCommands
    [Transaction(TransactionMode.Manual)]
    public class PipeBreak : IExternalCommand
        public Result Execute(ExternalCommandData commandData,ref string message,ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            // Select a pipe
            Reference[] references = (Reference[])uidoc.Selection.PickObjects(ObjectType.Element, "Select pipes");
            foreach (Reference reference in references)
                Pipe pipe = doc.GetElement(reference) as Pipe;
                Line line = (pipe.Location as LocationCurve).Curve as Line;
                double length = line.Length;
                XYZ midPoint = line.Evaluate(0.5, true);
                using (Transaction tr = new Transaction(doc))
                    tr.Start("Opdelen leiding");
                    // Breek de leiding op het midpoint, geeft element id terug
                    ElementId newPipeId = PlumbingUtils.BreakCurve(doc, pipe.Id, midPoint);
                    // pipe ophalen vanaf het id als een pipe
                    Pipe newPipe = doc.GetElement(newPipeId) as Pipe;
                    //connector manager oproepen en connector van de pipe ophalen
                    foreach (Connector connector in pipe.ConnectorManager.Connectors)
                        //Punt connector is orginele connector punt
                        XYZ connectorOriginPoint = connector.Origin;
                        //Connectorset aanmaken
                        ConnectorSet newPipeConnectorSet = newPipe.ConnectorManager.Connectors;
                        foreach (Connector newConnector in newPipeConnectorSet)
                            if (newConnector.Origin.DistanceTo(connectorOriginPoint) < 0.01)
                                try
                                    doc.Create.NewUnionFitting(connector, newConnector);
                                catch { }
                                break;
                    tr.Commit();
                    return Result.Succeeded;
I guess it's in the reference line:
When I use the PickObject-Method it works fine, but it doesnt work with the PickObjects-Method
Can someone help me?
Kind Regards,
Jan Willem
Hi all,
using System;
using System.Net;
            // Select a pipe
                                try
                                catch { }
                                break;
                    tr.Commit();
Kind Regards,
Jan Willem
Labels (3)
3 REPLIES 3
jw.vanasselt
in reply to: jw.vanasselt
jw.vanasselt
Post can be deleted, line 70 was on wrong position.
jw.vanasselt
jw.vanasselt
jeremy_tammik
Thank you for letting us know the problem is resolved. Unfortunately, I do not know how to delete the post. I'll just mark it as solved by your fix.
