Resize the dockablepane
MiguelGT17
MiguelGT17
Hi folks,
Hope you all are doing well
I've the following dockablepane set to a minimun width of 560px.
However, I wish to embed a datagrid that will take more than 560px width when user clicks on Takeoffs. Is there a way to resize the dockable pane width? So far I only see doable set the minimun size width on initialization of the dockable pane but any workaround or suggestion on this topic is more than welcome.
All the best,
Miguel G.
jeremy_tammik
If you really need to go beyond the dockable pane limitations, it may be worthwhile considering the implementation of your own modeless WPF control instead. Sure, you would lose some of the Revit-ness, and you would gain more flexibility.
